1199s. Very Loose Feeling Gear Foot Lever, Can't Change Above 2nd And Slips Into Neutral.
Discussion in 'Technical Help' started by Dabiscuit, Oct 8, 2022.
  1. Check the gear lever hasn’t worked loose on the output shaft and that all connections in the external linkage are fastened correctly and haven’t worked loose.
    Failing which you’ll have to drain the oil and remove the crankcase cover to check the selector mechanism underneath :(
  2. Thank you. That is very helpful. I'll remove it soon and have a look.
