1200dvt Serie Oro Size
Discussion in 'Technical Help' started by laava, Aug 23, 2020.
  1. Just ordered these for my Multi. My question is; the std dia is 330mm and the serie oro are 320. Is it just a matter of removing the spacers from under the calipers? Just making sure..as there does not appear to be a 330mm option.
    Thanks in advance, Al
  2. Depends how thick the spacers are, if they are 5mm thick then yes. Also make sure the bolts are short enough not to bottom out in the mounting holes.
  3. Thanks Dave, yep they look like 5mm. Good point about the bolts tho, I will find out I guess when I pull them out...could also be, in that case, that the bolts may be too longer as well as too much shoulder length?
  4. It was the length that I was thinking of, you'll work it out mate.
  5. Turns out a glitch in the carpimoto site specifies the 320mm ones unless you order late model 1260 discs. So I have ordered the wrong ones at this stage, hopefully will get sorted...
