would Appreciate any one had same problem i just changed rear sprocket to 42 Teeth, took it out for a ride and the auto blipper has stopped working on Downshifting works fine up shift any one had the same
Pretty sure you need to go through the tyre calibration procedure, mine did the same when I went down a tooth on the front.
Thanks for that Ill try tomorrow I just put a Termignoni D19308040ITC on looks awesome. is it worth doing decat with Rapid Bike ?
