1299 1299
Discussion in 'Panigale' started by pauly, Dec 20, 2021.
  1. How much difference would a remap, decat and 2 teeth on the rear sprocket make to a 1299?
  2. A lot. You’ll struggle to keep the front end down :)
  3. My 99 R1 and K6 GSXR1000 were brilliant wheelie bikes. Even with the anti wheelie turned right down, the 1299 not as much :(.
  4. Just buy a V4 or S1000RR ;)
    Decat and a proper remap should free up the engine...isn't possible to go 1 down on the front?
  5. make a big difference in your bank balance. unless you go 2nd hand end cans, and should smooth the engine out somewhat too.
  6. I run 41, youll need a longer chain 106 links from memory and get either the supersprox bimetal or a good aluminioum one. Its a huge improvement in ridability and you will not notice any lack of top speed.
    Get Akra or Termi slip ons with the upmap and a K&N filter and you should be good to go, alternatively stay stock and get it dynoed.
  7. wonder if you could turbo a 1299?? :thinkingface:
  8. ^ Supercharger. No lag then.
  9. Maybe I should buy an R, and just kid myself it's faster.
  10. @pauly i know where there is a hyabusa turbo for sale.
  11. In terms of what?
    Acceleration
    Top end
    Power curve/delivery
    Torque curve/delivery
    Road manners
    It will make a difference, but without knowing what you want to achieve it's impossible to say if it will meet your goals.
  12. i run a 14 tooth front and RB evo on my 1299, regardless of exhaust it smooths out the low end drive a lot
  13. More use than top end to me now. Due to the mainly crappy roads in Lincolnshire. And I don't fancy chucking a load of dosh at some cans, if they don't fill in the mid range by say 10 bhp.
  14. You're ignoring my point Cook, as per usual. : unamused:.
    #14 pauly, Dec 21, 2021
  15. No wonder the anti wheelie did not stop the 99 R1 lifting the front ,as i don't think it had any :D
  16. It didn't stop the S1000RR doing it.
  17. i would also consider the Evo software update if your 1299 doesn't have it already.. as this changes the parameters for the TC and I found it less limiting after the software install ( drive out of corners was improved dramatically)
  18. depending on your bike, some seem to surge a lot with standard mapping and exhaust configuration in the lower revs,
    you can fix this with a remap or just a Rapid bike unit, mine adds 12 hp with the auto correction facility.
  19. do you have the akrapovic up -map installed as well?
  20. You running std pipes mate ?
