15mm Offset 6 Hole Pcd Discs X 4
Discussion in 'Wanted' started by Cranker V2, Jan 31, 2015.
  1. 4 off discs wanted with 15mm offset, 6 hole pcd for widetrack forks, prefer brembo but will consider others.
    #1 Cranker V2, Jan 31, 2015
  2. just asking but do wide track forks require 15 mm off set? you sure?
  3. No they dont, spacers can be used to bring the discs out. However, as the phonic ring is needed for the TCS the 5mm spacer cause space management issues.
  4. ahhh, space issues with your ring....you went for the TC system them from Bikesport...
  5. yes my ring is fouling.
    (though I can use 10mm offsets if I machine sensor mount bracket and get a different length axle spacer)
  6. I can do the above mods if needed.
