There is a really nice 2017 Multistrada 1200 for sale on here and it is the non-Skyhook model. I have Givi Dolomiti cases and top box that I want to keep, but I have looked on the Givi site and it gives the racks as PLR7406CAM as the correct fitting for Monokey Camside which I think means Givi Trekker cases, but it also says “only for S version/18mm dia” Has anyone fitted Givi Dolomiti cases to their 2015-2018 Multistrada and give me advise? Is there any difference between the mounting system/sub-frame on the 1200 and 1200S models? This could be a deal breaker for my Ducati ownership.
If you use the plr7406cam you also need the kit for the 950 that moves the rear shock adjuster to clear the frame. I did the same thing on my pikes peak with ohlins
