Afternoon all! I've gone and lit my check engine light after removin the valve servo and replacing with a Healtech servo remover. This didn't work, the pins fit, but the connector was the wrong shape (must have changed it for 2018) and the light came on on second startup. I've since replaced the servo sans cable, as per the akro installation instructions, however the light is still illuminated, I can hear the servo actuating and it travels its full length, so I assume it's just 'remembering' the issue from previous. TL;DR, can you reset the CEL without handing over to a dealer? Thanks,
Welcome, I can’t hrlp you with that one but if you post this in the ‘technical help’ section Im sure you’ll get a quicker response. Also, it would be a good idea to introduce yourself in the Newbie section.
