V4 24 Multi V4 Rally Wheel Torque
Discussion in 'Multistrada' started by Sharpedge, Oct 26, 2025 at 12:51 PM.
  1. There is so much info (misinformation) of torque values online that I don’t know what the true spec are. I’m swapping out my tyres and need the torque settings for the front and back wheels. The back is of most concern as I have seen everything between 180Nm to 240Nm. If there if a link to all the torque values, it would be gratefully received.
  2. 180 rear nm this is my setting on my V4s multi , I think the front id 60 nm and the pinch bolts 10 nm but will check as have the all the settings. If you take the front wheel out remember to settle the front fork in before you tighten everything up and also pump the brake and hold it on as you tighten the callipers.
    There is a link on here somewhere, I’m sure someone better than me to post link as I’m not good at that
  3. The dual sided swingarm v4 Mutleys use 180Nm for the rear axle nut. It’s a 36mm 12point nut so you need a 12point socket . I found a 3ft breaker bar came in handy when loosening mine. My DesertX uses same torque & nut size which is handy.
  4. 230nm is for the single sided wheels. Yours is 180nm
