I was having a blast at the weekend when the dash went blank and I lost power, thankfully on a straight. A bit of roadside troubleshooting revealed that the 7.5A fuse on the headlight housing had blown. A quick check of the wiring diagram showed that the only things on that circuit are the killswitch, starter button and ECU. I checked the switches, all good, so am at a loss to understand why the fuse blew. I'm hoping it's not an ECU issue! Anyway, obviously no garages in the area carried fuses so I had it recovered home, stuck a new fuse in it and it's been as good as gold. Has anyone else had this issue and found out the root cause? I'd rather this didn't happen again mid-corner, it could have been a very different outcome.
Ok so I checked it over briefly before heading out and I couldn't find anything obvious. 50miles into the ride and the same thing happened. I had a fuse this time so stuck it in and rode home. I'll need to properly strip it down and test everything. I don't fancy the hefty bills involved in the workshop tracing an intermittent electrical problem.
