Got a bit of a project on the go..has anyone got any of the following bits hanging around please for the 748-998 bike? the fairing mounting brackets x 4 that bolt to the side of the frame a front track only style subframe rear brake lever mounting bracket assembly a pair of track rear sets ( not the std ones) worth a shot please?
Will it be ready for Portimao? Hasn't the special one got a load of bits, obviously as long as you can turn a blind eye to who actually owns them?
I have the front race fairing mount, I may have the some of the corse rear set parts. I’ll check but I may have 4 pot callipers too
For footrests you might want to look at some of the Chinese rear sets I have a set ( in use) cost £54 plus a few extra quid to buy ally spacers so they fit nicer
Can the boy not mill one from a billet or unobtanium that must be hanging round the workshop ? What you needs is a 3d printer ......
That's the style and place I got mine. There are several places selling them They do the same style for 916/999/1098 You can either fit them with road linkage or use the supplied gear lever that fits straight on the gearbox and gives you race shift @andyb
Can’t tell once done. As the bolts are normally recessed anyway. Did it to the NCR frame hangers I had on and worked/looked fine.
This answers a question @andyb, @bettes. I think what the Chinese have done is make the mounting holes 1/2mm out so they fit both One of the mounting bolts was tight on both sides When I fitted them I put both bolts in and tightened each one a small bit at a time till they were on
