Hello Folks! Wondering what the options are for 748 diagnostics, Would like access to TPS reset and CO trimmer. I use DucatiDiag on my 999 and it works a treat but from what I'm reading it doesn't work on older models? Any help is appreciated! Thanks, Connor
If you struggle getting a diag tool, you can go ‘old school’. Tbh, I still do it with out diag. The error reporting is crude at best. If you’re setting the fuelling up, then you don’t need a diag tool at all. The TPS is a manual set. Back probe the TPS and read voltage on a multi meter. There is no sw fuel trim. It’s done with a micro potentiometer in the ecu and fine tuned with the air bleeds. Look up bikeboy on the ‘net and have a trawl thru his articles on setting the fuelling up.
