Just wondered if other owners have found this. Due to the after market Termi pipes, I can only see to use one screw under the fairing casing. There normally is 2 screws, but because of the size of the exhaust, I can only use 1. Is this normal? thanks
Normal, had the same problem on my 999S with an Akrapovic system. With plastic fairings and 'banana' Termignoni both fasteners could be used.
My 749R with 57mm Termi has two Dzus to join the panels at the bottom. One is a bastard to fit however.
It is possible to get two on. It just takes time. I use a screwdriver to push through one of the pairs of holes to get the rear one in and then put the front one in
