Can anyone tell me if the 749 has more than the fuel pump relay and the headlight relay, whilst my new to me 749 has no bodywork on I might as well change these for new.
The headlight relay is located above the front wheel. Look up under the wheel and remove the black panel using the four allen bolts. Then looking from the front reach up to the left or shine a torch inside and you will see the relay located in a rubber housing.
