Evening chums... I'm after a bracket to fit ohlins damper... might get a ducabike one unless one of you guys have a cheap one kicking around...
Hi mate. I think I have a std one in a box of bits at home. I can check Friday when I get home if you’re still looking? Ian
Cheers Andy. Soz Chiz I thought it might have been as I got a crate full of 996 and a few 999 bits. Any ideas what it might be off? Ian
@chizel mate try mh racing in chippenham mark is an ohlins dealer ,ok you might pay a bit more if he can get one but it Will be right.
Ian asked if I knew where the bracket fits. On the ti header thread, there is a sp5 with a side mount damper bracket. The same type he has. I wasnt pointing you in the direction of one for you. Sorry for any confusion..
My friend just told me it should be off of a tangent not on a tangent but anyhu a bracket is required...
i remembered i have these bits..from a 2003 999R i believe the only bit missing is No 20 spacer to the frame...
