749r Little Oil Leak
Discussion in '749 / 999' started by clueless, Feb 21, 2014.
  1. I'v just noticed a few little drops of oil on the garage floor this evening.
    I put my hand inside the fairing and it's a bit oily !
    I'm hoping it's not too serious but I'm fearing the worst.
    What's the worst and best case scenario for my poor little bike and of course the cost ?
    Thanks :frown:
  2. I'll take it off your hands for £500.
    Just to save you the inconvenience and expense :wink:
    #2 deleteduser211220, Feb 21, 2014
  3. Some idea of where its leaking from?
  4. Not sure. The engine I think !
  5. First check would be the oil filter for tightness.
  6. Check the oil cooler hoses and unions.
  7. first check would be the oil cooler lines fittings at the engine end...
  8. ...and then the base of the vertical cylinder
  9. Thank you. :)
  10. How's it looking?
  11. I'm too scared to look until my mate comes round. :)
  12. The only oil leak I have had came from the breather at the back of the vertical cylinder .
  13. Your tub of Vaseline has slipped inside the fairing.
  14. Has it been standing for a while ? My 999s had a similar small oil leak that stopped once the engine got warmed up. Never had the problem again.
  15. I'v only got a little one Peter, so I'v never needed vaseline !
    I rode it last weekend and about 4 weeks ago !
  16. Oil filter is usual culprit.
  17. My 999s had a leak from 1 of the oil cooler hose connections , where the fitting connected to the engine .
  18. my 748r had a pin hole in the crank case that was a ball bag!!
  19. Is the oil pressure sender still be pain in the arse on the Testastretta's that is was on the 916 series?
  20. is this not bottomed out and sorted yet??
