Took the LHS fairing off and when putting back on found that one of the rubberised fixings had perished and came apart. This is the fixing that has a nut encapsulated within the rubber and attaches to the front underside of the fairing. Anyone know what this is called and where I can source a replacement - I don't have a Ducati dealer near me so was hoping to be able to get it sent to me if possible. Cheers Stuart
Its called a RAWL NUT....its an M6x1 and you should be able to get them from a good engineering supply dealer. If you cant I have some, so can send you a few. They are ABOUT £1 each ish.....
Thanks for the reply - does the raul thing include the rubber housing as I have the nut but it is the rubber housing bit that has fallen apart? Cheers
You will find the part number in here Ducati Motorcycle Parts - Buy Genuine OEM Ducati Motorcycle Parts from Pandora's European Motorsports | Pandora's Ducati Parts
Thanks for the link Mr C - unfortunately based in USA so shipping cost will be high in relation to the cost of the fixing. cheers
Also known as 'Well nuts' freely available on e bay, here is an example: 10 X M6 RUBBER NUT MOTORBIKE FAIRING WELL NUT X 10 | eBay
