750ssie Oil Light
Discussion in 'Technical Help' started by silver fox, May 18, 2018.
  1. oil light flickers when engine is hot and ticking over,never cold and goes out on any increase in revs.Presume this is probably wear in the oil pump, is this a known problem ?Any suggestions would be appreciated. The bike is just coming up to 29000 miles and the oil and filter have done about 500 miles.Thanks for any help.
  2. Probably the sender unit, cheap to replace to find out.
  3. Thanks Dave checked the pressure switch today found it leaking oil up into the cable so have ordered a new one.
