so as you know if you remove the cables you get a cel alarm so to bypass it you need to buy a full termi system with the ducati race ECU or you can buy one of these trick bits so firstly remove the right hand fairing and the exhaust shield. under the fairing you will find the exhaust servo this has to go, unbolt it, unplug it and remove the exhaust cables the other end of the cables go into the exhaust valve(under the exhaust heat shield), just take them off.the spring on the valve will hold it permanently open now fit the MotoCreations servo eliminator now put the fairing and heat shield back on as the hard work is now done as well as added noise you can save some weight bonus servo and cables new replacement and the all important noise test lol this cost me $162 which is about £100 posted. its all got a 5 year warranty and I done a lot of reading about them and have found nothing bad said about them. get them here http://www.motocreations.com/ducEE.asp the owner mark savory is very helpful and will help you with any questions... email is [email protected]
gives the bike a better note and at arounf 5k there is slightly more power.was trying to find the dyno I got done before an after.with the servo fitted there is a slight dip.....oh and its louder now
On my Streetfighter I just removed the cable that closes the valve at the exhaust end, no warning light and the spring holds the valve open. Its been like that for 2 years now - no problems
Ar right like the flapper valve mod on a blade I'd guess, ie there to stifle noise for the regs so there's a dip in power at the 4-5k mark and smoothes that out??
yeah, just like the old flapper mod.all for noise reg. its not that much of a dip, probably that little that its a placebo effect when you do the mod but I would swear I can feel the difference as I put the standard servo back on as the bike is getting sold soon.
