well, this is a hard ad to write.... :frown: My little yellow shed is potentially up for sale and will go if a decent offer is received. I am looking for a new machine for next year, so would consider swap/px WHY? Spec is as follows: http://ducatiforum.co.uk/members/cranker-v2-albums256.htm 1997 748sp frame with logbook Aluminium subframe 748R motor with 853 conversion 127bhp 71ft/lbs balanced crank lightweight flywheel 996 dual injector throttle bodies SP lightweight cam rollers Corse flowed heads Power commander Keyless ignition Sigma slipper clutch Vented clutch crancase SFS coolant hoses Race type carbon airtubes Brembo radial billet brake master cylinder Bembo 999 radial clutch master cylinder Ducati Performance flip up clutch lever Cornerspeed clutch slave cylinder HEL black braided brack lines Corse rearsets Corse carbon dash and upper fairing/ecu mount SPA tacho with with shift lights Silmotor 45-50-54 exhaust system (carbon cans) dB killers Woodcraft clip ons Magnesium upper and lower yokes Ohlins R&T forks Performance Technology monoblock calipers Ohlins rear Shock Ohlins steering damper Corse adjustable ride height link HM quickshifter (race pattern) Carbon underseat tray Marvic magnesium wheels (6" rear - Dunlop KR slicks fitted) Wets on Wheels (five spoke marchesini) Technosel race seat Ilmberger Carbon swingarm protector Carbon front mudguard Carbon heel protectors Carbon rear hugger Carbon airbox Aluminium race front wheel spindle Titanium front and rear axle nuts (1 front 2 rear) Titanium caliper bolts Titanium top yoke bolts Brembo cast iron fully floating discs (dry wheels) Brembo stainless discs (wet wheels) Renthal kevlar grips Lightweight engine bolt kit Race fairing Ohlins steering damper Harris steering damper fitting kit Corse screen Renthal sprocket carrier Renthal rear sprocket Race fuel cap Corse underseat breather Carbon battery box Cornerspeed clutch slave cylinder Belt change August 2013 View attachment 18981 View attachment 18982 View attachment 18983 View attachment 18984 View attachment 18985 View attachment 18986 Bike is in Chester area. Better pics to be added this week.
The pics are a few months out of date, a fair few bits not fitted at the time. My bad :frown:. new pics later this week
I can't get them to sit the right way up. I even downloaded them and edited them in Preview - but when I loaded them up to Photobucket, they turned around again. So I rotated them around in Photobucket and uploaded them to the forum and they turned around again. So I gave up. (it not being my bike...) Sorry.
