900 Ss Showa Shock Bearing
Discussion in 'Supersport (1974-2007)' started by Scottiebike, May 7, 2021.
  1. tried searching for previous posts - not a lot! MOT today have got an advisory regards slight play in rear shock bottom bearing on my 93 900 ss.
    It is a showa - will I have to strip it out to measure / find a part number?
    Any recommendations for suppliers?
    thanks
  2. You might find that’s its not the bearing bush that’s worn so much as the bolt itself has fretted a little.
    I had that some years ago and just replaced the bolt. I can’t remember if it was the bottom or top.
  3. bought some from my local bearing supplier when i changed mine fair easy job if your handy with tools
  4. thanks for info guys - going into garage now to strip out the shock and remove the bearing!
  5. Watch for the bearing retainer spring clip flying across the garage!
  6. Got it out without too much bother - spring clip bit fiddly to get out! Bearing is very dirty / rusty - only done 10k miles :-(
    Top hats in VG condition, outer seals okish.
    Ordered a replacement from simplybearings.co.uk
    #7 Scottiebike, May 8, 2021
  7. dont think they last a long time get covered in debris and water etc
    small amount of play in the bearing fells like 2 inches of travel in the suspension
    most bikes have bushes in the suspension but no ducati go all out with a bearing lol
  8. All fixed - very fast delivery from simply bearings :) Zero play now!
