916 916 Belt Change Service, How Longs It Take?
Discussion in '748 / 916 / 996 / 998' started by Cinko, May 23, 2018.
Tags:
  1. Need to do a belt change service on a 916, belts plugs and fluids... anyone know an estimated Mount of time it will take do have done at a service shop?
  2. Nevermind, got it in the shop to day. For records, at my local shop its a 2 hours charge for just the belts.
  3. That seems fair to me as there is a bit of work to remove bits and pieces to access the belts:upyeah:
  4. Fairing and battery tray removal takes about 10 mins.
    Tank and airbox another 10.
    Actual job can take the remaining time.
    2 hours sounds reasonable all in.
  5. Agreed 2 hours seems fair, unless you have an EVR airbox which has the throttle bodies inside it, requiring removal of everything and then re-sealing the airbox and checking of TPS/throttle balance etc. when re-assembling.
    Plenty of scuffed knuckles re-fitting the throttle cable and breather hoses, need to add an hour on but since everything is apart I always think, might as well check the valves and rockers whilst in there. I schedule it during the winter months when I can take my time.
    Best way would be to have a racing style airbox with removable sides, that would save time as you could do the rear cylinder belt with airbox in place...
  6. Just to follow up, I brought the bike in with the plastics off.
    The airbox has the carbon fiber intakes which just pop out
    Would have done it myself if I had time... to many other projects right now.
  7. I have a mechanic friend that can change the belts in a few minutes and have them to the right tension. I took off the covers and he carried on. The time aspect seems to be on the mechanic if they know the model. A ducati mechanic should be the quickest.
  8. change the belts in a few minutes...............very much like to see that in action:thinkingface:
  9. Did my own 748 belts today 2,5 hrs but Im not a Duc engineer
  10. Did my own 748 belts today 2,5 hrs but Im not a Duc engineer
