916 916 Handlebar Clamps
Discussion in '748 / 916 / 996 / 998' started by don quixote, May 25, 2022.
  1. Hey All,
    I need to replace a cracked handlebar clamp. Spoken to motorapido. Only supplied from Ducati with the handlebars at around £250 each. I want to replace both sides because, well, why wouldn't you replace both 27-year-old parts at the same time... But £500 total is a no go.
    I can't find the clamps anywhere on Ebay.
    Please can somebody point me in the right direction?
    Kind regards.
    DQ
    #1 don quixote, May 25, 2022
  2. That sucks. There are any number of generic clamps available, usually sold by diameter. So 56/22 for example is 56mm fork diameter and 22mm handlebar diameter. A lot of them are one piece and require you to slide the forks down so you can get the clamp in but otherwise they are a option. Can't help with OEM.
  3. i take it they are single bolt fork clamp ?? i think i have a pair of single bolt
  4. Note, there is a locator pin on OEM bar end clamps, which fit in a recess on top yoke to set the angle of the bars.
    I'm sure I'm teaching you to suck eggs, but these are not generally included in aftermarket variants.
  5. theres 2 sorts ,,single bolt fork clamp and two bolt,, the handle bar clamp are all 2 bolt so has your clamps got a total of 3 or 4 bolts,, they both have the locator pin for top yolk
  6. I have replaced my Showas with ohlins on my 748sps
    I also have a 1098.
    The bars from the 1088 are flatter and fit the 748
    I would think 1098 Showa bars fit 748 showa forks
    This is the one I need. 2 bolts attaching to the handlebars, 1 bolt attaching to the fork, and a 1 pin opposite.
    Thank you so far for all the replies.
  8. Not at all, im a total novice and welcome any and all advice!
  9. Did you have a look to see if you have what im looking for Stu? :innocent:
  10. I have a pair date stamped 1997 , with or without bars,, message me if you need to know more
