Has anyone got one the small 90 degree clips to stop the rear pad pin falling out? I can get one with a new pin for £8 from ducati but theres nothing wrong the pin i have. Its the type that clips into a groove rather than the R type clips on the front calipers.
Have you tried a KTM or direct Brembo delaer, it might be cheaper. I know the clip you mean I have seen a couple of those rot on early bikes so they are not that common to have as a spare.
I don't trust the small circular clip that fits in a groove......I have several of them (from various other applications) but they seem so easy to flip off...... ....so I drilled a 1.0mm diameter hole through the pin just past the groove and there is now an R-Clip in the pin as well as the round clip.....
