While brakes are ok with higher speeds and when you need lots of braking power, but front brake is very difficult with lower speeds and when you need less braking power. Braking causes trembling and braking power isn't smooth. Specially when brakes are cold. Only 950 I have ever driven is my own so I can't compare brakes with other similar bike. Is this typical?
After service and some sofware updates front brakes are better. I got servicing to borrow a Multistrada 950, the difference in brakes is considerable. Multistrada's brakes took a soft grip at the slow pace. HyperMotard still seems to fiddle. There is no fault with the brakes per se. The ABS worked fine when the deer tried to come into the arms.
