A big thanks to 'juZ' on this site.
Discussion in 'Lounge' started by CRYSTALJOHN, Jul 17, 2012.
  1. Well done that man!
  2. You're welcome :upyeah:
    Hopefully see you at Boxhill soon.
  3. I read all the above with interest. - Any idea what the cause was in the end?...........Oh, and a big :upyeah: for JuZ from me too.
  4. Wrecked
    The engine management light that was re-set, so far has not made a reappearance. Nothing was actually done to the car, apart from me disconnecting the Lambda sensor and running with it disconnected for a 100 miles or so, which seemed to make the engine run normally. Now after JuZ re-set the light, the car appears to run perfectly, I am however prepared for the thing to make a reappearance just when I think the problems have been solved. As this is the way of things!
    Could have been :
    1. some bad quality petrol? I don't know if that could activate the engine management light, but I suppose it's a possibility.
    2. faulty Lambda sensor, or about to come to the end of it's life?
    3. fluctuation in the space time continuum?
