Does anyone have a surplus ST4S Immo antenna, the one that plugs into the separate immo box? It is the one with the white multi plug not the 2 way Superseal connector. I have a little key project to try and identify why some transponders are giving unusual code readings. It is part of my project to calculate the bypass codes for the 2 key bikes. I know I have done the immo bypass for quite a few forum members so you may have one surplus to requirements. Anyone willing to donate an antenna? I will cover P&P
Chris, my son is currently converting an ST4s into a Paul Smart Replica (ish). The ECU is one on which you previously disabled the immobiliser function. As far as I know he still has the immobiliser and antenna which I'm sure he will part with as he hasn't got any use for them. I'll ask. He is currently working night shift so it might be a day or 2 before I get an answer for you.
That would be great. What I can do is virginise the immo box for him. He could then sell the immo box as virgin to recoup some of his build costs.
