Abs
Discussion in 'Technical Help' started by Cream_Revenge, Apr 30, 2016.
  1. How do you tell if a bike has ABS?
    Is brake bleeding/fluid change any different on a ABS bike?
  2. Look at the inside of the disc rota - toward the axel, and if you see a spindle that looks like a 'railway track' it probably has ABS
    No difference in bleeding the fluid
  3. Awesome, a sensible answer, thx.
  4. Trace the fluid line(s) coming out of the master cylinder. If they go directly down to the front calipers, no ABS. Looking for a toothed rotor on the wheel won't confirm it; bikes like RSV4s have had a rotor front and back since 2011 for the aPRC electronics, but ABS was added only recently.
    Bleeding is the same as on a non-ABS bike but more difficult since the pipe runs are longer. There is a post on elsewhere on here about how hard it is to bleed the brakes on a Multistrada with ABS, and a potential solution.
