Adjustable Clutch Lever
Discussion in 'Technical Help' started by panigale66, May 30, 2020.
  1. I need a adjustable clutch lever on my hyperstrada cos the stretch is just a little bit too far away and affects my shoulder after a while, with an adjustable lever set nearer to the bar do you still get the same amount of operation on the clutch?
    Rich
  2. No, but as long as there is enough lift to free the plates to enable neutral selection it is no problem. Consequently you might not be able to adjust the lever as close as you might like. I have adjustable levers on both my Scrambler and my Supersport to help reduce the long reach with the OEM levers.
