Alternative Fuel Pump For Desmoquattro Bikes
Discussion in 'Technical Help' started by Martin D, Jul 4, 2018.
  1. .
    #1 Martin D, Jul 4, 2018
  2. Bosh Fuel pump.......
    Bosh part number 0580 453 408
    for 748 916 996 ST's 620 750 900 ssie (can be used on SS carb but you need the connector for the loom)
    Toyota Corrolla 1998-2002 ( Toyota p/n 23211-46070 & 23221-21020)
    Mazda 626 1992-1994
    Aftermarket: IFP Indiana 912 or GE 043
    This is in the Technical section under alternative parts, post no six.
    It might help.
    Steve
  3. Again, you just wriggle/pull it off, it could be that the pump body is rusty so the massive surface area will make it appear to be glued, it has locating flanges that make it harder to remove but maybe warming up somehow might help.
  4. Worth a try, it will be useful for us all if it lasts OK.
    Steve
  5. Nice foot note :eyes: lost in translation I guess!
    Don't hesitate to buy, you will get the following item.Package Includes:
    1 Piece Fuel Pump
    Note:
    Please allow 0.5-1 inch difference due to manual measurement.(1 inch=2.54cm)
  6. sorry I am late to post - can recommend above and have bought 3 so far/used 2.
  7. If the relay is hotter than normal Martin, it might be an indication that more current is flowing is flowing through it, although I can't come up with any reason why that might be.
    Once the contacts are latched into position, there could possibly be more current flowing across the contacts as maybe the new pump is tight and consequently the motor needs to work harder resulting in more current flow.
    Give it a little while and it might ease up as the pump beds in.
