Alternative magnetic sump plug
Discussion in '748 / 916 / 996 / 998' started by Haydn, Jan 25, 2014.
  1. Anybody using a hex head magnetic sump plug instead of the crappy OEM one. Avintia racing do one but its not magnetic as its aluminium.
    Cheers
    Haydn
  2. u could buy and glue a magnet to it
  3. Hmm would rather not have anything in my engine/oil which is glued tbh.
  4. fair play
    was looking at these myself the other day
  5. Thats smart I wonder if they do it for the 916
    EDIT yes they do just found it.
  6. #6 Haydn, Jan 25, 2014
  7. Looks good to Tim, I presume with the O ring and being Ali that you just nip it up rather than the standard torque figure to crush the washers.
  8. I used the normal torque but you'd probably get away with less. The magnet is stronger than the original part though.
  9. Did / does the magnet catch anything lately?
  10. A few years back I had a couple of valve seals work off the guide and get mashed by the rockers.
    The little filter was full of bits of red rubber & the usual chrome (rockers) :rolleyes: ... but some of the body of the seal was stuck to the magnet. :upyeah:
  11. That magnet is also glued in place!
    If you want to avoid glued/resin magnets, look for ones that have been riveted in place like the oem magnets.
  12. The one that Tim put a link to clearly shows the magnet held in with a circlip.
