1200 DVT Anybody Got A 1jac Ore Constand For The Dvt?
Discussion in 'Multistrada' started by Schifi, Dec 13, 2015.
  1. Hi guys,
    Anybody already got a 1Jac ore ConStand for the DVT??
    I was thinking about it, but not sure if it is as good and easy to use as in the video's.
    Your comments please :blush:
  2. Saw this at bike show but put off because it won't fit to a F650GS which is the wife's bike so a non starter. Looks well put together tho.
  3. I bought one for my VFR1200 (Constand)
    Stands are well built
    Very difficult to hold the bike upright and wiggle the the stand in place on the VFR.
    I succeeded - but was not happy doing it.
    I then bought the front wheel chock - but unless you bolt that down - it was not sturdy enough to hold the VFR on its own.
    Trying the combination (Stand and chock (before bolting)) - I nearly dropped the VFR - and got trapped between it and my tool box - luckily - I had phone in my pocket and was able to call for help - luckily - just scratched frame where stand rubbed.
    With the chock bolted - the issue is getting it out of the chock and back in the chock to take it off the stand.
    So they work fine - but are tricky to use - suggest you get an assistant to help you.
    The VFR is 40 or 50KG heavier than the multi.
    I contacted them 3 or 4 months ago for new adapters for the DVT and Scrambler - they were not available then.
    So have not tried it on Multi.
  4. ;)
    #4 Hyperextended, Dec 13, 2015
