1200 Anyone Used These Or Similar?
Discussion in 'Multistrada' started by NSR500, Oct 31, 2016.
  1. AZ5 Kit - Throttlemeister
    I have a few issues with my grip and power in my hand these days, does anyone have experience of this set up or similar?
  2. Hi... Those look like bar-end weights or have I missed something in the link.?
    However, I too have a bad right hand/wrist but not too much an issue with the mut. i went for a quick action throttle on my last sports bike which reduced the twist range by a good 25/30%
    Might be something worth looking at...
    Various out there but mine was by ACTIVE.
    Hope that's of some use.
  3. Grip puppies also help with vibrations as its a thick peice of smongy rubber.
  4. I had them on my VFR 1200 - I bought the black heavies - in stainless with stainless machining.
    Good Quality and really quick delivery.
    The throttle lock worked well too.
  5. My bad... I looked at the website and all is now clear.
  6. The idea was that the heavier the weight the more it would dial out vibration that sometimes is blamed for numbness and tingling. A cheaper way I had on a older bike was to get some foam cycle grips and fit those over the existing grips which reduced it quite a bit.
