What are you guys using to remove the front and rear wheels ? Socket size and where I can buy the specific one for the Hyper 950 SP. Is it better to use a impact drill to remove them since they are hard to remove? Thanks.
Hi Jose Front wheel Needs a 30mm socket,undo the pinch bolts on that side aswell. Rear wheel nut is 46mm I believe. If you haven’t got an air gun get someone to hold the back brake and use a strong bar. Hope this helps? Dave
Thank you, I was watching a video of someone using a impact drill in reverse and it worked great, just thought that would be easier if I am by myself??
Deffo - I use one of these... https://www.screwfix.com/p/makita-dtw450z-18v-li-ion-lxt-cordless-impact-wrench-bare/5445j
Depends on the Nm - mine is 440Nm Max, but that is for fastening, the undoing torque is usually much more than the max tightening torque for some reason. Only use for undoing, use a torque wrench for tightening...
https://www.amazon.com/gp/product/B00G6KMYCU/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 This is what I use for the rear nut.
I’ve got the one above its 46mm one side and 41mm the other, so you can remove the wheel or change sprockets, works a treat.
I was looking at this one. https://www.motomfg.com/STEEL_Ducati_41mm_46mm_wheel_nut_socket_p/wh-5.htm
Best quality large sockets I've ever had..... https://www.bikerstoolbox.co.uk Nice and shallow, great fit and impact applicable
