998 Back wheel nut blues I have b******d an Oberon socket and am now going to take the mountain to Mohammed i.e. the bike to the impact driver... This nut is rediculous a naff design if ever there was one. I have used a 46mm CV socket with a 4' extension bar having heated the nut and applied candle wax (old school) after soaking in penetrating oil for a week, my mate stood on the bar whilst my wife held the bike on the back brake. The nut didn't move. If impact air tools don't work then it's a torque converter if that doesn't work then I guess it's cut it off and re build the back wheel. How have other people faired with this problem?
Four foot square section steel bar onto 46mm socket with 1/2" adapter + one big Scotsman bouncing up and down on the end... no kilt thank god
Ride to your local garage, get them to use the impact tool on it, tighten it back up. Ride home, do it your self. Chuck em a 5er. Sorted
My stepdad had a similar problem with his rear wheel nut, until he realised he was turning it the wrong way (after snapping TWO - one of which was mine, breaker bars!!!).:redface: This was on an MV F4 which has a LEFT hand thread... Came off OK with a bloody long bar, turning it the right way
I got myself one of these after a similar experience of swearing & sweating with the hub nuts on my Clio... 1/2" 12V Impact Wrench Kit 350Nm RAC 038/2364 12 VOLT (5013433012101) | eBay 350Nm will get most stuff undone, good price too! :biggrin:
Just as an aside to this, the best penetrating/release fluid you can possibly use is a DIY mix it yourself job. 50:50 acetone and automatic transmission fluid. No wind up, no joking. It is better (Scientifically proven) than anything you can buy :smile:
Googled this and yep - does appear to work a treat! Bit troubled by acetone being nail polish/paint remover though...
By the way, current bikes (Multistrada, Diavel etc) require a larger 55mm socket, not 46mm, for the rear wheel nut. I got a really massive 12-point 3/4in drive steel socket, which undoes the nut pretty well (provided you jump up and down on the end of a scaffold pole).
