998 Barnett Clutch Basket
Discussion in '748 / 916 / 996 / 998' started by The real Ray, Jan 20, 2021.
  1. Anyone on here used a Barnett Clutch basket on a 998? the type with the steel inserts.
    If so did you use OEM clutch plates or Barnett clutch plates?
    The 998 is being awoken from its "period of rest" in the garage:) and the main pullarver is the clutch, the MPL clutch basket currently fiitted (the one with the titanium inserts) is worn out and you can't get replacement MPL inserts these days.
  2. I've used a Barnett basket for my slipper clutch and also for the standard clutch. It works just fine.
    I think they are a good option being light as an aluminium one but won't get chewed out so quickly
