Battery
Discussion in 'Supersport (1974-2007)' started by Harris911, May 19, 2020.
  1. anyone used a jmt jmb gel battery? Are they any good?
  2. I just removed an Li and installed an AGM. First day went awesome
    Rex
  3. Harris, lower CCA than AGM lead acid batteries which might be a problem in the winter, higher cost than the equivalent OEM (and most reliable) Yuasa AGM, similar weight. The battery is OK but why bother?
