Belts Question !!!! Before Do Some Damages
Discussion in 'Technical Help' started by Paolone, May 7, 2020.
  1. I have 2 Ducati and i don't use them a lot time ago (1 or 2 year)2 years ago i had change belts in all bikes... From the maintence's Ducati book, i have read Ducati suggest to change them every 2 years or 20.000 km.
    i think i dont need change them... they have 300/400 km of work
    #1 Paolone, May 7, 2020
  2. It depends on the bike. Ducatis up to about 2010 or so we're 12,000 miles or 2 years. Later bikes 15,000 miles or 3 years, then 15,000 miles or 5 years. Some of latest bikes are at 18,000 miles or 5 years, there have been some changes to the belts though.
    For a low miles bike you should be ok for 3 years.
  3. a friend with original byke changed his belts after 7 years and 12.000 km
    #3 Paolone, May 7, 2020
  4. That's fast :eek:
    *edit, just seen your full stop wasn't a comma, 12mph :)
  5. ops sorry 12.000 km:D just edited !!!o_O
    #5 Paolone, May 7, 2020
  6. Is that 12 kph or 12000 kph o_O
  7. 12000
  8. Lost in translation I think, 12,000 kph = 12,000 kilometres per hour which is quite fast for a Ducati o_O for distance we say 12,000 km :):upyeah:
  9. yep sorry
  10. Probably more reason to change them after you no use it a lot... rather t gf in one that’s in use daily...
    They get deformed to a shape sitting still!
  11. Belt pulley Bearings actually cause more problems through seizure as the grease hardens with age causing them to run hot .
