Best Crankcase Breather Set-up
Discussion in 'Technical Help' started by Pablo Pirate, Apr 30, 2013.
  1. Howdo!
    Wondering what the best set-up for the crankcase breather is & if the one I have is really suitable??
    My Set-Up.
    STM Breather with the reeds removed.
    Hose from the breather to the seat (Seat has a cubby hole behind the seat pad - about 4-5litres).
    This hose is connected to a Corse reed valve in the seat.
    The seat is vented by a round K&N style air filter.
    Didn't run back to the airbox due to the limited space on the bike (Superlight).
    Guessing I would benefit by having a large space between the engine & Reed Vv or move the Reed Vv further down the chain some how?
    Also took the bike for a top speed blast and had faint smell of fuel in the breather set-up?? Blow by??
    Any advice welcome.
    Cheers Pablo
  2. Why not junk the whole lot and run a large bore hose (25mm) from the crankcase outlet up and out to the rear?
    Most of my single and twin cylinder bikes were done like that.......never had any issues; IE oil drip or dirt/water in.
    And you won't smell it........but yep, I reckon what you are suggesting is blow-by, but I would have thought you would see oil in the breather.
    AL
  3. A better set up would be to have the corse reed valve on the exit of the box, that way you add the volume of the box to that of the crankcase.
  4. And use a race-style breather that is larger bore than a breather with reeds, then use larger bore hoses to the breather box etc. with the reed valve as the last item. That way you maximise the volume before the reeds. Can't imagine it makes much difference but every little helps...
  5. That's how i run mine too, Reed valve is last thing in the system.
  6. Not missed the trick its just that I don't want to run to the airbox, I appreciate that moving the reed valve increases the physical size of the engine - so to speak, reducing crankcase pressure. Just trying to adapt my set-up and it's a bit of a compromise as not everyone can goto there WSB parts bin like some church mouses I know.
    • Nuke Post Nuke Post x 1
  7. Is it like the 916/1098 set-up?
    Have a K&N stylie on mine, quick, dirty and simple...Bit like me...:smile:
  8. Well I didn't want to have the reed valve in the airbox - for several reasons, oil in the airbox, just made the airbox and didn't want to trash it, space due to the wiring loom down that side & trying to keep the bike looking tidy as you can see it all with the half fairings(Winter will see a new leaner better fitting loom).
    As for junking the K&N & replacing with the reed Vv too late.................moved all the wiring and drilled me bloody air box! Reed Vv is now back in the bloody air box :rolleyes:
    soooooo need to get a corse breather and larger hose (Waiting to hear about a 2nd hand one - fingers crossed).
    Just need to finish it off and try the bike again, will knock up a proper catch tank over the winter. Hopefully this will reduce the crankcase pressure and reduce the odd bit of oil being spat out...........be glad when it's finished.
  9. Hey RWBHP bar room cock swingers how you doing ? :upyeah:
  10. That's what I did!
    VeeTwo large crank case breather, no reed and a big bore tube. venting under the seat and out the back. :)
    #10 Sev, May 2, 2013
  11. Thanks for that Steve. Now the thing is, it's an old aircooled engine, it's not built to do anything other than make me smile.
    There's no oil mist at the zone where it exits, which is nowhere near the back wheel.
    Now, last time I looked, I didn't have a PCV system, and the original breather tanks whilst being woefully under baffled unlike the ones I used to make for illmor vented to the air box which was also running an open filter.
    Now I'm all ears, so tell me the theory and the maths for why I should contemplate replacing the breather tank come under tray I made for my old girl many years back.
    And if you could tell me the correct volume for my engine that would be pretty cool too as I'm sure the people I discussed this subject and specifically how it pertained to my bike probably didn't know jack.
    So... Im all ears as you in essence have the answer to pablo's question, and I'm sure that a lot of other readers would welcome the knowledge also.
    Some calculations would help too.
  12. Sev, your spot on mate. The pipework and other associated b**locks fitted as standard is purely to satisfy the environmentalist and emission numpties. The system is not pressurised and feeds back into the airbox which is open to the atmosphere. From the crankcase you can route your breather pipe wherever you want. I have removed the entire system and blocked up the resultant hole in the airbox. Fitted a K&N breather directly to the crankcase......job done. Run this for 6 years with out a single problem. Chris B
  13. SEV and RAGERTY-------------- please read and pause for thought
    Shazaam's Tech Library - Oil Breather/Ventilation
    A useful technical article from guest contributor Larry Kelly of San Diego CA (aka Shazaam!).
    The only reasons to replace the breather unit on the crankcase ventilation system is because it's leaking or you're getting excessive oil into the airbox (or you just want to dress-up your bike.)
    The stock set-up is the best. The STM reedless breather unit is used only as part of a high compression Corsa set-up to deal with additional blow-by. Here's why ...
    Blow-By
    Piston rings act as a seal between the high pressure created in an engine’s combustion chamber and the lower pressure in the crankcase. Blow-by occurs as the rings become worn - or fail to seal properly when new - and they allow a small fraction of combustion gases to leak into the crankcase.
    The consequences is accelerated contamination of the engine oil, as well as excessive release of hydrocarbons to the atmosphere - unless a crankcase ventilation system is used to route the gases back to the engine intake to be burned.
    On Ducati engines, excessive blow-by can cause unusually-large amounts of entrained engine oil to be forced through the crankcase ventilation system and into the airbox. It’s not unusual however, to occasionally see a light deposit of oil in a Ducati airbox.
    A small number of Ducati 998's, maybe one percent, have been reported to build up so much crankcase pressure at high revs that excessive entrained oil is forced/sucked into the airbox through the crankcase ventilation system, resulting in excessive oil consumption.
    Blow-by occurs in all engines to varying degrees as they wear, but when it becomes excessive, an engine rebuild with new piston rings is in order.
    Crankcase Ventilation
    Crankcase ventilation is used for three reasons:
    It reduces crankcase pressures to nearly atmospheric pressure in order to avoid oil leaks from seals and gaskets.
    It reduces crankcase pressures at the bottom of the pistons to provide an increase in the differential pressure across the piston compression rings, and consequently provide an increase of torque and horsepower. A larger differential pressure across the piston oil rings also aids in control of oil consumption.
    It reduces pumping losses. In a running engine, the size and shape of the crankcase boundary changes with the movement of the pistons. Ventilating the crankcase reduces parasitic horsepower losses involved in compressing and moving this air volume about, so net power output is increased.
    The larger the crankcase volume, the less-compressed the gases it contains become, so the lower the losses. If you vent directly to the atmosphere - through a sufficiently large vent hole - the crankcase can’t attain positive pressure, even at the highest engine rpm. Further, if you create a vacuum in a crankcase, the effect on pressures is the same as increasing the crankcase volume.
    It’s interesting to note that in the automobile performance world that there have been performance gains using crankcase ventilation systems that create a vacuum in the crankcase using pumps and extractors.
    Ventilation Systems
    The simplest way to ventilate the crankcase is to create crankcase openings to the atmosphere large enough to permit any combustion gases that have made it past the piston rings (called blow-by) to rush out. In this case, a filter element is needed on the opening to prevent dirt from entering the engine. This system was used on engines for many years until environmental laws required a modification that prevented direct release of this effluent to the outside air.
    Gary Milcheck Photo
    The design result of such laws is a positive crankcase ventilation (PCV) that uses the lower-than-atmospheric pressure that normally exists in the engine intake tract to extract the crankcase gases. These are then are burned along with the normal mixture of air and fuel. This system has a one-way valve that allows outward flow only, and a oil separator that acts like a maze for any entrained oil droplets that try to leave the crankcase. This (normally) small amount of oil then drains back into the crankcase instead of entering the engine intake.
    On Ducati street bikes the one-way reed valve is located at the engine case opening. During certain conditions of high engine rpm and light load, more oil is entrained so the reed valves’ small drain holes have difficulty returning the additional oil to the sump quick enough. The oil separator can fill with oil and get sucked into the intake tract. Higher compression engines or worn piston rings have more blow-by, so the likelihood of oil being puked into the airbox is greater.
    Because of this, and to gain about a two horsepower increase, race bikes that live at high-rpm use a somewhat different arrangement than the street bikes. A much larger oil separator box is used to effectively increase crankcase volume that reduces pressures and pumping losses.
    To allow the oil to drain back more quickly, the reed valve with its small drain holes is removed from the crankcase location.
    Gary Milcheck Photo
    The corsa box is connected to the crankcase with a large diameter hose and located a greater distance away from the crankcase opening, under the tail. The one-way reed valve is now located at the airbox connection of the 3/4-inch vacuum line running to the oil separator. This design reduces the chances of contaminating your intake charge with oil. It also provides a large enclosed system that safely contains the oil if an engine blows.
    Except for the larger oil separator volume, the advantages of the corsa system can be implemented in the stock system by hollowing-out the reed valve to remove the constriction on drainage. Alternatively, STM valveless breather connector can be used. Then use a one-way reed valve at the airbox connection. A 748RS remote breather valve works well here.
    More conversion photo can be found here:
    http://public.fotki.com/garymilcheck/motorcycles/748r/corse_cb_install/
    K&N Breather Conversions
    The K&N breather is sold on the premise that venting to the infinite volume of the atmosphere - instead of the vacuum in the airbox - increases horsepower. It eliminates the one-way valve so it needs an air filter to prevent dirt from entering the crankcase under a negative crankcase pressure differential (pulse) when a piston is on an upstroke. Under positive crankcase pressures, the K&N device simply vents oil droplets direct to the filter medium - and beyond when it becomes saturated.
    People usually buy them because they look trick mounted on the engine case. Therein lies its main disadvantage. Its location on the engine case is directly upstream of the rear tire. Since its installation also eliminates the oil separator, the increased chance of an oil mist being released onto the rear tire makes this location an unwise choice. Avoid overfilling the oil sump and wheelies with this arrangement.
    Consequently, some owners have plumbed to the K&N element located in the tail where, at least, any effluent is away from the rear tire.
    Here’s what the experts say ...
    The following is a earlier post by BCM Ducati:
    What is different about Ducati streetbike breathers in general is that the reed valve is mounted directly in the case. The breather box location and volume are good.
    The reed valve location is good for emissions but not for engine power and crankcase breathing. What happens is that under certain conditions, under high rpm and light load, the oil doesn't run back because of the reed valve and it builds up in the tube above the reed.
    The simplest solution is to hollow out the reed assembly and leave it internally open but still hitched to the volume bottle. This allows the volume of the breather bottle to perform its function and usually gives a slight horsepower increase also.
    Then, use either a 748RS reed valve in the airbox at the end of the breather hose, OR, use a Ford diverter valve (in-line one way) just before the airbox.
    The following is a earlier post by Jon Nichols:
    We firmly believe the best system is the stock system. Let me expand on this. The only part worth replacing is the breather itself, and only if it is leaking or if you want to dress-up your bike. We see many Ducati's with the K&N filter attached to the breather hose. This is simply not a satisfactory replacement or alteration to replace the stock system. The stock system is less restrictive because there is more volume making it less restrictive.
    Part of the problem with this modification is that the only efficient replacement systems made were made for race circumstances. This was accomplished by increasing the tank volume into which the engine pumps. On the early bikes, 851, 888, 955 in the 851/888 chassis Ducati had a very large carbon fiber tank which was connected to the engine crankcase without any breather. The tank was mounted in the tail section of the bike. This effectively doubled the crankcase volume and was responsible for an additional 3 to 5 HP at high RPMs.
    This type of system is also available for the 748/916/996 chassis. This type of system is not available for Monsters or SS models, unfortunately. Therefore, the system that allows you the largest volume to pump into is the stock system. This system pumps into the airbox and has the added benefit of a collection/separation tank between the crankcase and the airbox.
