848 Best Gearing For 848 Evo
Discussion in '848 / 1098 / 1198' started by Anthony848, Feb 19, 2017.
  1. To lower the gearing, is it better to get a smaller front sprocket or larger rear? Is it 15-39 stock? Also which brand chain and sprockets are best?
  2. 14 front and 39 rear
    Sent from my iPad using Tapatalk
  3. Generally I believe it's better to go up on back as its more even chain wear and the front is not such a small pivot for the chain/tighter radius. Also less strain on output shaft I think I read. Costs more and you may need an extra link for +3.
    14t front is easier.
    Look on gearingcommander.com
  4. 14/39, works on road and most tracks :)
    If you want to know the impact on speed etc for different combinations check here
    www.gearingcommander.com
  5. I tried 15/40 15/41 and 14/39. 14/39 was the most noticeable improvement (no surprise), and definitely the one I'd recommend.
  6. Ok thanks, I'll go for 14-39. Any recommendations for which brand?
  7. Always Renthal from B&C Express for me.
  8. I've got a slightly used 14T sprocket you can have for £10.00 posted
  9. Does the standard chain fit a 41 tooth rear sprocket OK?
