Bought in August this year to move the bike from front to back of house,new house where I don’t need this now So ForSale Dolly Mover with front wheel chock for motorbikes and scooters Load Capacity 450 kg Dimensions: Length 212 cm, outer width 27 cm, inner width 21 cm, weight 38.5 kg Suitable for rear tires up to 200 mm width Motorcycle is simply driven on the rail and stands safely and stable thanks to the wheel chock for the front wheel Adjustable for front wheels of 15-21 inches and 90-180 mm width Four easy-running polyamide double casters with brake (75 mm diameter) ensure low force and stable stand Handle for easy maneuvering of the rail without motorcycle Steel thickness of 3 mm, absolutely torsion-resistant even at full load Perfect for easy handling and parking, even in small garages or confined spaces Due to the firm design also for long-term use, e.g. for hibernation Looking for £150 must be collected from the Cheshire area due to size and weight
