1200 Bit Of Help Needed Re Sprocket Carrier
Discussion in 'Multistrada' started by knightrider, Aug 17, 2014.
  1. Going to get my carrier powder coated so was going to take off today ..... But my question is can I remove the carrier without taking everything else off ( wheel, chain and sprocket, 55mm nuts and what size Allen key to stop the back from spinning
    thanks
  2. I believe you can, but you will have to loose the chain completely and then loose the LHS 55mm nut. You should have the carrier + sprocket in your hands at that point with everything else in place.
