Bits for a dry clutch
Discussion in 'Wanted' started by He11cat, Apr 13, 2013.
  1. I have monster M900 casing
    Now looking for
    Matching crank gears
    Correct oil pump gear
    Dry clutch friction plates
    Pressure plate
  2. Someone tried to inbox me ... I have emptied it a bit
  3. If the pressure plate is universal between a 1098 and a monster, I have one you can have
  4. Don't do it! A wet clutch is so much nicer to use. If you want the noise strap a tambourine to the bike. I'm on my phone so can't find the link but there's a funny 848 clip on YouTube :upyeah:
  5. Yes I have seen that.
    i really want one.
    il have to remove a couple of springs though like my other bike as my hands are pretty weak.
  6. Tell you what.........instead of going to all the trouble of changing all the casing and clutch over, just fit the sprocket cover I just made for my 750SS.................It is 1.5mm polished aluminium and it rings like a bloody bell.......even with an old oil seal araldited on the inside (you should hear it without it)............
    .........it amplifies the engine and adds the ring to it so much, that I have just removed it and black CF vinyl wrapped the OEM plastic one.........(anyone want a white CF one?)
    AL
  7. I've got an Ali sprocket cover on mine as well :)
    I so wish I could also find a set of nice high level termis that fit my little bike :(
    But not at mental prices.
  8. How are you doing on the parts?
  9. So far got oil seal,engine casing which I hope will fit!!!
    I hopefully have A M900 pressure plate.
    That's it so far.
    Still lots to get!!!!!
    Kato said when he has time he will have a look he may have some bits.
    I'm having to get a bit at a time as the bits are quite pricey!
  10. As I've said Mel, I can nachine bits you need. sadly have no bits you need.
    Hopefully with the goodwill from members here, we can sort you out (ooeer) And you can fulfill your dreams.
  11. Thank you just got some bolts and springs !
    its going to be a long haul then getting it sorted but worth it in the end.
