Icon Blank Dash Screen ???
Discussion in 'Scrambler' started by Hannann, Sep 23, 2019.
  1. Hi has anyone else had a problem with their dash
    I have a 2016 icon, when I turn the key all of the functions on the outside ring flash up as normal but the centre of the LED screen lights up and nothing is displayed. There is no speedo reading or odometer reading, just a blank screen.
    I am assuming I need a new dash but thought I would post this in the hope that someone has an easy fix
    Thanks
  2. I think someone on the scramblerforum had a similar problem a year or two back. I'm fairly sure a new dash was required.
  3. Thanks
    It is unusual that the functions around the outer ring are working and the centre screen is blank.
    I checked the display fuse and it looks ok. I will ring round a few dealerships to see if they have come across this problem before
  4. I spoke to a couple of Ducati dealers to see if they had come across this problem. One said they had a bike in with a similar problem which had a broken power wire at the headstock. I checked mine with a continuity tester and the two power cables that run from the fuse are fine so it looks like a dash problem.
    Has anyone used a digital dash repair company that they could recommend.
    Thanks
  5. did you guys ever figure it out
    I have an HM1100s 2008 with similar issues, the dash is blank, all other electricals work, the bike doesn't start
    remove and replug the starter relay harness and it starts working again, till the next power off.
