Quick Question if I’m replacing anodised bleeder screws on the callipers back to stock do I need to bleed the system or can I just unscrew them and fit replacements with no issues
Cheers guys is it ok to remove the old nipple with fluid in the system without it all escaping then fit the new part and carry out a bleed?
I have done this - you will likely get a little bit of fluid coming out so make sure you have something to catch it to prevent paint damage etc. Do the swap really quickly to minimise loss. Also you mention anodised nipples - are they ally?
