Blown Tailight/brakelight
Discussion in 'Sport Classic' started by Old Fart, Sep 19, 2015.
  1. Hi guys i'm hoping someone here can help.As the weather is improving over here went for a night ride and found i had no tail light or brakelight.Took the lens cap off and both filaments are smoked.Replaced the globe and it works but both filaments glow so no visible brakelight,what's wrong?? hope someone can help,thanks.
  2. What's it doing with new bulbs fitted ?
  3. i would suspect the pres sensor in the brake hydraulics line,,, disconnect and see then..
  4. Possible you've lost an earth? It sounds to me like the electrikery is looking for alternate route to earth
    Did you check no bake light on application of both back & front brake? If so then its unlikely to be a switch/pressure switch fault
    Is it glowing like the normal tail light and the brake just not operating at all or does something else happen to the light when the brakes are applied
    If the former likely a break somewhere in the brake light wiring think its red/green, if the latter then possibly earth, black wire.
    Do the indicators work as they should? Are they glowing too?
  5. Thank you for the replies.Indicators work normally.With a new bulb both filaments are glowing when i turn the ignition switch on so no brake light when i squeeze the lever on depress the rear brake pedal.
  6. Stop tail bulbs have staggered locating pins, you have to put them in the right way round.
  7. I think two of you have already covered the possibilities looking at the symptoms - the current is either 'back-e.m.f.-ing' due to a poor earth in connection with one or both the circuits (sidelight/brake) OR one of the brakelight switches has jammed on (or if it's an earth-return switch then a wire from switch is damaged and earthing somewhere). As said, disconnecting one brake-light switch at a time is a nice easy test that I would try first.
  8. Thank you for the tips i'm going to work my way through what you guys have said.
    • Dislike Dislike x 1
  9. I cheated and took it to an auto sparky.The little spring loaded plunger on the rear brake pedal switch had snapped off so the rear brake light was on full time till it smoked the bulb.Thanks for your answers guys.
