Stripping my 2003 998 Bitsa Loads of nice rare bits for sale, Here's a list of the bits ive managed to think of so far, more maybe added. Some prices may seem expensive, however i have had to base most of it on what things have sold for on ebay, then tried to make them a little cheaper. Bike is stipped, everything is cleaned and bagged where possible. All parts are 998 however most will fit any of the 748/916/996/998 series bikes...some parts will also fit later bikes...like mudguard, sprocket cover etc *PLEASE ASK IF UNSURE* I will combine items for and discount accoordingly. Everything must be sold down to every last nut and bolt! All prices exclude postage, i will however post as cheap as possible, please ask for a price. I will accept paypal as payment however buer must send as a gift or cover the transaction fee of 3.4%. A bank transfer is my prefered method of payment as is a whole lot easier for both parties and free. All parts are in good condition however please ask for a condition description and i will happily take photos of any marks. Photos on request Please either reply to this thread or start a conversation with me if interested in anything. Appologies for the rant, just want to make sure i can keep up with sales. Cheers Tom Ducati 998 Bits for sale 998 Frame with V5 black powder coated (hpi clear on 03reg) with tax and mot + eccentric head tube perfect for 1098/1198 conversion (could do a deal with loom, coils etc?) - £1000 Swing arm + hub + eccentric + rental quick release sprocket adapter and 520 renthal sprocket + all nuts (gold painted magnesium look) - £350 Mono alloy subframe - £225 – provisionally sold Headlight bucket with ears (black powder coated) - £100 Ducati 998R lower Yoke 56mm (Ohlins fitment) - £220 Gold anodised top yoke (Magnesium look) - £60 Ohlins FG8851 forks 996R/998R (10/01/2001) - £900 Brembo P4 front calipers Gold 4 pad type (998R) - £155 Ducati braded front brake lines to suit p4 calipers (998R) - £15 Brembo Cast Iron fully floating disks (early type like found on foggy reps and sps) - £280 Front axle + Alloy Nut - £25 Carbon Fibre Front mudguard (MS Production?) looks to be 848 type - £80 Titanium Front disk bolts £10 Standard front caliper bolts - £4 Standard clip-ons (lever lugs removed for aftermarket Brembo,s) - £40 provisionally sold Left hand switch gear - £35 Right hand switch gear - £25 Brembo Billet Clutch Master Cylinder with folding lever + res bracket - £220 Brembo Billet Brake master cylinder with folding lever (19x18) + res bracket BOXED - £285 Front Brake reservoir - £10 Clutch Reservoir - £10 Throttle assembly + cable - £25 Headlight - £170 Headlight bucket to frame bracket - £10 Transligic micro dash with carbon Corse type mount + front wheel blank (includes all wiring so more or less plug and play) - £350 Ducati Performance Carbon Air Tubes with inline filters (included) + indicator mounts - £200 Ducati performance small Carbon Mirrors *RARE* - £175 Front left indicator - £10 Front right indicator - £10 Rear Right indicator - £10 Rear Left Indicator - £10 Ohlins 998R Steering damper and bracket - £255 Ducati Performance Carbon Radiator surround/V piece (998) - £80 998 Radiators - £100 998 rad fans - £25 each Standard Rad hoses 998 - £30 996R engine, Sand Cast cases, Deep Sump, Corse vented clutch engine case, 3300k miles,) Just been dyno’d, running well at 137bhp 5/8/2014 – dyno man seemed to think its had some cam work…his dyno runs low so could be 140+ (no numbers F01 stamped!) Has been rebuilt at somepoint, has “Ducati Manchester” race team roots…more info on request (will have fresh belts and filter when buyer is secured) -£1800 Oil cooler and lines - £120 Termignoli full 54mm system with Titanium cans (VERY VERY RARE) including rare heat shield - £1200 996R ECU set up to run with the above (61600.630.00 – 996R-DUCATI007) - £200 Brand new motobat Battery (only been mounted in the bike) with box and fittings - £35 Standard 998 air box painted black with carbon wrap on sides - £85 Airbox fastenings - £10 Ducati Performance red star type radial clutch pressure plate + spings + bolts - £80 Corse Type rear sets with both pedals £100 Corse Carbon heal guards - £20 provisionally sold Ducati performance Titanium sprocket cover - £80 Open clutch cover - £20 Ducati performance chain guard - £60 998 fairing lowers to suit belly pan (red with graphite painted vents) - £170 Side stand + bracket + spring etc - £65 Zink coated allen bolts for fairing to fairing + wellnuts - £10 Lockset with 2 keys - £80 Ohlins 998R rear shock DU8420 - £330 Shock linkage + Ride height bar - £30 996r/998 Injectors + Rail trumpets etc (998) - £150 Throttle body fuel hose and connectors - £10 998 Battery box with regulator bracket…slight repair - £40 Brembo rear master cylinder - £30 Rear Master Cylinder bracket + light switch (sticking) - £10 Braded rear brake line - £5 Rear brake reservoir - £5 MS Production/LLmberger Carbon underseat heat shield - £100 Ducati Performance Carbon Number plate holder - £45 Rear number plate light - £10 Rear disc- £35 Rear disk bolts - £5 Swing arm pivot axle - £20 Brembo rear brake calliper - £35 998 coils - £40 998 regulator/rectifier - £20 Fuel pump - £80 Rear brake light - £25 5 spoke Alloy Marchesini Wheels (black powder coated) with Pirelli super corsas - £650 Brand New Avanti black anodised rear wheel nut - £10 Genuine Ducati Carbon Belly Pan 996/998R/S (road type) - £160 Suede covered seat in black/dark grey (genuine mono) - £85 Seat hinge - £10 Mono seat rear light bracket - £25 748R mono seat, recently painted (painted panels but with vents) gold fine lining RED - £300 RED fuel Tank with black decals (recently painted) - £300 RED genuine nose cone, white number board with gold fine lining, black decal (recently painted) - £200 Expansion tanks for rad - £30 Provisionally sold Crank breather tank - £20 Dzus fastening kit - £50 Main wiring loom (996r/998) - £200 22 pin Front wiring loom - £50 Fuel pump solenoid - £20 Horn - £5 Standard Brembo later style front brake master and lever (bleed nipple snapped, good for spares) - £25 Fuel tank pin and fastenings - £10 Rear brake calliper bracket - £15 Exhaust hanger brackets - £15 provisionally sold Fuel pump fastenings - £5 provisionally sold Clutch push rod + bearing - £5 Windscreen, bottom tint with rubber trim - £15 Copper exhaust header nuts - £5 Top engine bolts/mounts x2 - £20 Clutch and friction plates (worn but usable) - £15 DID 520 chain, good condition - £45 Air Temp sensor - £5 998 later large bore Slave cylinder - £20 Head race bearings - £5 Rear wheel clips x2 large and small - £5 Loads of various stainless fastenings all bagged and labled, could do a package (please ask)
Hi mate, You'll need the 56mm lower yoke..top yokes fine. What Calipers are you running? I notice your bikes a later 748..measure the centres between your bolts...they should be 65mm. If so I could do a deal with the lower yoke? Tom
i am interesting in the Translogic micro dash. can you send me a mail. i don't find a button to send you a pn. thanks manfred
Hi Tom, Have you still got those two left and right side fairing top halves? are they carbon?... Davidx
I have yes, however one is at the painters at the moment being refinished. There standard 998s plastic. Tom
