For Sale Brembo 100mm M50 Monobloc Front Brake Calipers
Discussion in 'Parts, Accessories & Clothing For Sale' started by AJL277, Aug 16, 2018.
  1. For sale a pair of Brembo M50 front calipers removed from my 1299s.
    Included are the bleed nipples bango bolts and pads with 3000 miles road use.
    Price £395.00 plus postage.
    20180816_182947.jpg 20180816_182739.jpg 20180816_182947.jpg 20180816_182739.jpg
  2. That's a very good deal. Someone will get a bargain. Good luck with the sale
  3. Cheaper than the discs..
  4. Is it right that these were designed for 330 mm discs, and fitting them on something that has 320mm units will require shortening of the fork support ? Assuming it has no spacer fitted.
    What is the width of these please.
  5. Hi Pete at work now so will look tonight when I get home.
  6. The 1299s has 5mm (loose) spacers between the caliper and the fork radial mounting to accomodate the 330mm diameter discs. If you have 320mm discs, just omit the 5mm spacers. Andy
  7. Not on my forks that have no spacers.
    Just done a bit of research and found they have 30mm pistons instead of the M4 which are 34 mm pistons, so does the Pani have a 16mm master cylinder
  8. Not really a bargain, they are £500 new delivered . . .
  9. Then go and buy new at £500
    These are as new at £395
    #10 AJL277, Aug 18, 2018
  10. There’s no need to cry, just pointing out that brand new ones without the 3000 miles of wear, are available for £100 more.
    A bargain is £300, £400 is just the 20% vat off
  11. get em waz....then you get to spend even more money on an rcs....i can whole heartedly say that the m50 caliper is better than the m4 (got m50's/rcs17) setup on my rsv4....
    Ps i think youve still got KTM forum-itis where once bought everything is worth fuck all!! :)
