Brembo Calliper Pitch Bolt Torque
Discussion in 'Technical Help' started by Nostromo, May 4, 2020.
  1. Looking for the spec for the pinch bolts on brembo callipers, silly me thought the info would be readily available online but I cannot find a straight answer, do I go by the bolt spec?
    cheers
  2. When you say 'pinch bolt', are you talking about the M10 caliper securing bolts ? If you are, my 1098R M4 calipers are 43 Nm. Andy
  3. Hi Andy
    No I mean the bolts that hold the two calliper halves together.
    Cheers
  4. Or are you talking about the bolts holding together the 2 halves of the calipers on older models, not radially mounted?
    If so on my Carby 900ss it was 33Nm, I used the same setting on my S4R as I couldn't find a torque setting for this bike.
  5. Hi.
    Goldline torque is 28 - 32 NM and Brembo recommend you use blue loctite
  6. Radials same as the ones found on the 999r
    Cheers I’ll go for 32
  7. Cheers I’ll go for 32 with blue
