I've got this pair of front discs that are no good to me. Used, but hardly worn at all with no wear lip they look at though they've hardly done any miles at all. They could do with a good scrub which I'll do if I end up putting them on ebay for more than I'm offering them for on here. But they are a very useable set if yours are worn and you are not looking for a perfect finish. I've had them on my surface plate and can't find any warp in them. I believe they fit lots of later Ducatis, but can't tell you what. Genuine Brembo 300mm OD 64mm ID 6 hole fitting on 80mm PCD ZERO Offset £60 collected from Clanfield Hants, or + £8 P&P within the normal UK limits.
