Hi guys can someone explain what the numbers mean please? Ie 19-18 or 19-20 I'm looking at putting one on my other bike but not sure which one I need. Cheers
Basically 19/20 for non Brembo OE calipers and 19/18 for Brembo OE caliper. I have just fitted a 19/18 for my stock 748R calipers and hoping for a little more feel and less on or off switch like. Andy
I should have added that is for twin discs. The link @Nelson posted makes for informative reading. Andy
Bear in mind if you go for the RCS system you can vary the lever/plunger pivot point distance so for instance instead of 19x18 or 19x20 it's 19x(18 or 20)
This you will have, I use the 19x18 with those discs and calipers along with EBCHH pads, simply marvellous setup.
